Replace by Condition ERROR
Ciao Everybody,
i really can´t get why this ReplaceByCondition does not work. I can read a list of Revit rooms, the same out of Excel, I can compare them. Now I wish Dynamo to replace item of Revit list with the ones from Excel, every time they do not match.
What am I doing wrong?
Error states:
Warning: One or more of the input types are not matching. Couldn’t find a version of __Replace that takes arguments of type (__array,__array,__array)
Thanks a lot!
The condition has to evaluate true or false itself (see the definition in the dictionary if needed: http://dictionary.dynamobim.com/#/Core/List/Action/ReplaceByCondition)
See also this topic:
http://dynamobim.org/forums/topic/replacing-items-in-a-list-based-on-search-criteria/
Amazing Yna_Db, Thanks!
So, i´m picking up the wrong node. Would you suggest to use another one insted?
Thanks!
PS: a Code with a simple IF() works fine :wink:
got it|690x391
You’re right, If works also. We can not see your image, but here are some details for anyone interested:
http://dynamoprimer.com/en/04_The-Building-Blocks-of-Programs/4-3_logic.html
