Alien
1
I have a structured list (in this example there are three numbers in each sub-list)
If one of the numbers == 0 I want to replace it depending on which index it’s at.
So if it’s at index [0] I want to replace it with 3500
if it’s at index [1] I want to replace it with 4000
This is what I have so far… But the ReplaceByCondition has no levels.
@Alien Try this:
[x[0]==0?3500:x[0],
x[1]==0?4000:x[1],
x[2]==0?5000:x[2]];
Take your list. Transpose. You’ll then have 3 lists running parallel.
Do your ReplaceByCondition on the 2nd list.
Then transpose back.
Or just do it in python which is more straightforward.
This should give you the right idea.
Alien
4
Heh, I tried it like this but the List.GetItemAtIndex doesn’t seem to like nested lists…
So it works how you suggested
However I won’t always have a list of length 3. Any suggestions how to do it with x length list… Should I just resort to Python?
Just duplicate your replacement values so your lists match. Problem solved.
