Has anyone found a good way to change the order of your Watch Nodes for Dynamo Player without deleting and recreate them?
The only way is to recreate the.
The best way I have found is to click and drag while holding CTRL (@kennyb6). This will copy the node with the strings attached. Do this in the order you want and bingo!
Don’t forget to delete the old ones.
Does it work with alt for you? I have to use CTRL and drag.
Thanks… this works using CTRL key.
