Hi All
Trust you’re doing well.
I’m working on tiling layouts for a temple project.
To build the tiling on site we are dividing the pattern into a series of mats.
To show these mats on a drawing I’ve created a detail item (red in drawingTile Mat.rfa (328 KB) ) in Revit with a parameter called “Mat Label”
The issue I’m having is numbering this parameter in a particular order. I want the mats to be number from left to right starting from the top. I’ve seen a forum here in which this was done for beams.
How do I go about doing this for detail items?
Please see images and dyn file attached showing my attempt.
Thanks in advance. @Vikram_Subbaiah @jacob.small Mat Numbering.dyn (18.1 KB)
Well, your tiles are on a grid, and you have drawn the grid’s extents as dashed lines, so…
- Get all of the tile families in this installation
- Pull the location of the tile mat elements.
- Select the top dashed edge of the overall installation with a select edge or select model element node and pull it’s curve.
- Get the distance from the edge to each tile point and round to a reasonable tolerance.
- Group the list of tiles (#1) by the associated distance to the top line (#4) with a List.GroupByKey node. You should now have a list of sublists of tile rows.
- Get the location of each tile - note that you will want to watch your list structure from here on to make sure that the depth stays @L3.
- Select the left dashed edge of the overall install using a select edge or select model element node and pull it’s curve.
- Get the distance from each of the grouped rows of tile location points to the left curve.
- Use a List.SortByKey node to sort the list of groups of tiles (#5) by the distance to the left line (#8). Set the list level to @L2 for both inputs.
- Flatten them list (unless you want to have a ‘row’ tag as well, in which do that step before you flatten anything).
- Build your mark value as desired (
“”+(1..List.Count(n)); might be your goal).
Thanks so much.
I’ll have a go. Much appreciated.
Thanks Jacob. For some reason this doesn’t work well when I use different family types so I had to change all to the same family type and use instance parameters to control width dimensions. Thanks again.
Here’s the dyn file. Mat Numbering.dyn (38.5 KB)
