Rename System Family Types
I’m trying to rename wall types. I want to add prefix per type mark. Clockwork node Element.setname is not working. Why? What am I missing?
is there any python alternative?
rename system types, i thought it was for pipe or duct :wink: i would call it rename walltypes…however the clockwork node is written in python
the clockwork node is not working
Im sending you the graph
Add Prefix to Wall Floor and Roof Names Per Type Mark.dyn (23.4 KB)
yeah i understand…what happens if you disconnect to illigal charachters
nothing
which revit version are you in ?
2024
do you have a small rvt as well you could share
seems work fine here…do you have the right ironpython installed ?
I did not install any ironpython. What should i look for?
install this one here from PM Manager and should work
I just did that, but it is still not working
and you are sure its version 2.5 you installed
oh no, I will fix that rn
Your solution works! Thank you very much! Should I also install IronPython3 version 1.0.0. for other nodes?
no dont think so if in 24
ok
