Rename System Families and Types
Hi - I have seen lots of posts on this topic but am having no luck finding a solution to this question.
I am trying to rename system family and types in a project. I start with ‘Element Types’ to select all the system family content I will be working with, pull this into a list, collect element types, and then try to get the Family and Type name for the elements.
No ‘Element.GetParameterValueByName’ or version of return the Family or Type parameters as text? and even if I go through and filter family and type (preference to have these separate though) from a list of all parameters I can search the bool result?
Hi @jaclyn.s,
What happens when you put an “Element.ElementType” node between the “All Elements of Type” and “Flatten” node ?
Kind regards,
Mark
Hi @MJB-online - thanks!!
That helps work out the type rename if I use Element.SetName!
Is there an equivalent node that might work for the family rename for system families?
I was trying Element.SetParameterByName by this returns only nulls.
Thanks for your help!
if you are comfortable with python you can use the ‘filtered element collector’ to get the element ids for system family types, then pass that to clockwork’s Element.SetName
formatting is slightly different when using python from string
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import \\
Element, FilteredElementCollector, BuiltInCategory,\\
CeilingType, FillPatternElement, FilledRegionType, FloorType,\\
GraphicsStyleType, RoofType, WallType
from Autodesk.Revit.DB.Architecture import \\
HandRailType, RailingType, StairsType, TopRailType
fec = FilteredElementCollector
ceilings = fec(doc).OfClass(CeilingType).ToElements()
fillpatterns = fec(doc).OfClass(FillPatternElement).ToElements()
filledregions = fec(doc).OfClass(FilledRegionType).ToElements()
floors = fec(doc).OfClass(FloorType).ToElements()
handrails = fec(doc).OfClass(HandRailType).ToElements()
railings = fec(doc).OfClass(RailingType).ToElements()
roofs = fec(doc).OfClass(RoofType).ToElements()
stairs = fec(doc).OfClass(StairsType).ToElements()
toprails = fec(doc).OfClass(TopRailType).ToElements()
walls = fec(doc).OfClass(WallType).ToElements()
elem_types = ceilings, fillpatterns, filledregions, floors, handrails, railings, roofs, stairs, toprails, walls
ceiling_names = [Element.Name.__get__(i) for i in ceilings]
fillpattern_names = [Element.Name.__get__(i) for i in fillpatterns]
filledregion_names = [Element.Name.__get__(i) for i in filledregions]
floor_names = [Element.Name.__get__(i) for i in floors]
handrail_names = [Element.Name.__get__(i) for i in handrails]
railing_names = [Element.Name.__get__(i) for i in railings]
roof_names = [Element.Name.__get__(i) for i in roofs]
stair_names = [Element.Name.__get__(i) for i in stairs]
toprail_names = [Element.Name.__get__(i) for i in toprails]
wall_names = [Element.Name.__get__(i) for i in walls]
elem_names = ceiling_names, fillpattern_names, filledregion_names, floor_names, handrail_names, railing_names, roof_names, stair_names, toprail_names, wall_names
OUT = elem_types, elem_names
still a padawan :slight_smile:
Thanks @adam_bear1 this is much more elegant than what I was trying!!
shorter version, not sure if this should be under share, but thought I’d put it here for now, might be useful to refer to if anyone wanted to make the class an input to the script…
from Autodesk.Revit.DB.Architecture import *
elem_types = []
elem_names = []
clazz = ('CeilingType' , 'FillPatternElement' , 'FilledRegionType',
'FloorType', 'HandRailType' , 'RailingType' , 'RoofType' , 'StairsType',
'TopRailType' , 'WallType')
for claz in clazz :
	elem_type = fec(doc).OfClass(eval(claz)).ToElements()
	elem_types.append(elem_type)
	for elems in elem_type :
		elem_name = Element.Name.__get__(elems)
		elem_names.append(elem_name)
improved thanks to post by @Kulkul, although there may have been a simpler way possibly…
clr.AddReference('DSCoreNodes')
import DSCore
elem_types = []
numtypes = []
elem_names = []
clazz = IN[0]
#clazz = ('CeilingType' , 'FillPatternElement' , 'FilledRegionType',
#'FloorType', 'HandRailType' , 'RailingType' , 'RoofType' , 'StairsType',
#'TopRailType' , 'WallType')
for claz in clazz :
	num_types = 0
		num_types += 1
	numtypes.append(num_types)
def list_chop (chop_list, chop_lengths) :
	# 'Kulkul https://forum.dynamobim.com/t/list-chop-problem/21357/7
	chopped_list = []
	sub_dex = 0 # 'inital index of item in sub list
	sub_length = 0 # 'initial sub list length
	while sub_dex < len(chop_list) and sub_length < len(chop_lengths) :
		sublist = []
		for i in range(int(chop_lengths[sub_length])) :
			if sub_dex < len(chop_list) :
				sublist.append(chop_list[sub_dex])
				sub_dex += 1
			else :
				break
		chopped_list.append(sublist)
		sub_length += 1
	return chopped_list
chopped_names = list_chop(elem_names,numtypes)
OUT = elem_types, chopped_names
Hi.
How about adding Structural Foundation types?
Hi @yasin.bosnali,
maybe someone can correct me, I couldn’t find a class for structural foundations, so I used the built in category instead…
hope that helps, stay safe ! #covid
a.
# if you want to load everything
#from Autodesk.Revit.DB import *
# if you would rather just load what you need
from Autodesk.Revit.DB import Element, FilteredElementCollector, BuiltInCategory
# we need to use clockworks chop function to return multiple lists
# of multiple categories of the same length for easy comaprison
# between category types and category names
def clock_chop_10 (chop_list, chop_lengths):
	# ' clockwork https://github.com/andydandy74/ClockworkForDynamo/blob/master/nodes/1.x/List.Chop%2B.dyf
	chopped = []
	count = 0
	max = len(chop_list)
	for num in chop_lengths :
		if count + num > max : end = max;
		else : end = count + num
		chopped.append(chop_list[count:end])
		count = end
	return chopped
cat_types = []
cat_names = []
type_elems = []
numtypes = []
# if you want to use fec to collect multiple built in catgories add them to this list
# it needs to be wrapped in a list otherwise we couldn't iterate of a single string
cats = ['OST_StructuralFoundation']
# in this example with only a single item in list we could simplify code to not iterate
# leaving like this allows others to more easily adapt to find multiple categoires
# to find other built in categories go to revitapidocs.com and search for BuiltInCategory Enumeration
# https://www.revitapidocs.com/2015/ba1c5b30-242f-5fdc-8ea9-ec3b61e6e722.htm
# element types are filtered out so that we only find the modelled instances not all category types
for cat in cats :
    cat_type = fec(doc).OfCategory(eval('BuiltInCategory.' + cat)).WhereElementIsNotElementType()
    cat_types.append(cat_type)
	# find the length of the list that we can use to chop lists
    num_types = 0
    for i in cat_type :
    	name = Element.Name.__get__(i)
    	cat_names.append(name)
    	num_types += 1
# chop the list of category names using the length
chopped_names = clock_chop_10(cat_names,numtypes)
# here we find the elements of the individual instances of the category types
# we filter out the elements that are the category types not the modelled instances
for cat_type in cat_types :
	type_elem = cat_type.WhereElementIsNotElementType().ToElements()
	type_elems.append(type_elem)
OUT = chopped_names, type_elems
It gives two empty lists. Can you check please or am I doing sthg wrong?
if you can send me a *.rvt I can have a look…
the above works for families, not system families, but unless you can tell me what type of system family you are modelling structural foundations from (wall? / floor?) I cant help sorry
How to rename these from:
System Family: 021- … to My021- …
or
System Family: 021- … to System Family: My21- …
does this code run on new versions? I am retrieving Nulls…
I´ve heard about changings in the api by rvt23?
greetings
Kev
