Hi
Is it possible in any way to change the type name in Revit with Dynamo? Maybe with Python?
Hi
Yes! Thank you…
@moeng,
Me also trying to change type name using the same script but i’m getting error at element.type node. Can you help on the same?
Hi!
I am also trying to change but with no success.
As I am beginner in Dynamo I would realy appriciate if you could help me with this problem.
What I want to do is change so the naming convention goes like this: “Family Name_WidthxHeight”.
Anyone idea?
I am sending screenshot of my current attempt with Dynamo script.
Thank you in advance for help!
After I cleared my head I found out where was my mistake
I will upload script if somebody will need.
Can you please upload it?? Thank you
Hi Tuan,
Here are two scripts - one for system families and one for non-system familes.
For system families, eg. “Walls”, I have added prefix “Z” in naming convetion - so the name of the Wall Type is for example: “Z-Basic Wall_25cm”. Ofcourse, if you don’t want this prefix you can easly remove it from script.
Hope script works good for you…let me know
Type Name-non-system families.dyn (19.5 KB)
Type Name-system familes.dyn (21.6 KB)
Thank you a lot!!!
Hi Kamel.
what naming convention would you like to use?
Best,
Martina
