biggest noob on the forum is back with an new issue.
I have been trying to rename my newly created assemblies but i can’t make it work. I have been searching around and tried alot of different ways but i don’t understand how to do it with assemblies. Is it not possible to do with CreatAssembly as a basis?
SteamNodes has “Tool.RenameAssembly” node.
Hi @jakob.hansson for me it looks like you have invalid input in the node, try open the node and correct as here…and save, but not 100 sure
thats the issue
I have noticed that one, however i did’t want to use it duo their warning. It works?
Yes it works.
It worked with “Select Model Element”. I dont understand it can’t work with “SelectInRevit”. Its basicly the same? Or is it becaouse SelectInRevit is for multiple elements?
I am not sure of the functionality of the “SelectInRevit” node, you may can try to place a transaction node between the that and the rename assembly node.
The rename assembly node works with a list also
