How to rename an Assembly instance? The existing package nodes are not working for me.
The Python code I am trying: RenameRevitAssembly.py · GitHub
The Python code started from Tool.RenameAssembly in SteamNodes.
Maybe Type vs Instance is my problem.
Does anyone have an example of a graph that uses Tool.RenameAssembly?
Hello @truevis
insert a Transaction.End Node (to Start a new Transaction)
or use
TransactionManager.Instance.ForceCloseTransaction()
Hello @truevis
Renaming the assembly requires a separate transaction
I cannot believe I spent a full day with a script to set the name of Assembly Types which code was correct but I had a warning that I did not know how to skip it, but this line of code just fixed TransactionManager.Instance.EnsureInTransaction(doc)
the warning was this:
script does not work because Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed.
File "<string>", line assembly_instance.AssemblyTypeName = assembly_name, in <module>
Exception: No valid type for the assembly instance.
Does closing transaction in Python also cause double Undos in Revit’s stack like the Transaction.End Node does?
In my case I have 3 undos of Dynamo for a python code, I did not really pay attention to it if the task is done. I already wrote 2 times this code line with no clue what it does really
