Rename a view parameter using sheet name not working at last node
Hello, i am trying to rename a view parameter via the sheet name but I am getting the error message shown below. The View Use Parameter is spelled right and everything but I cant figure out why else this isnt working it should just work but idk…did I lose the actual elements somehow. Please advise.
Hi @mix
You need to connect elements. Currently your feeding string values.
And also could you reply on your previous topic. Mark the post if it is solved.
