I am trying to rename multiple views that have been named using “Floor 1”
I filtered by parameter name and string.
But I keep getting a error from Revit.
here is a clip from my workspace.
I’m thinking I need to fix my list from FloorPlanName to ViewName but I’m not sure how.
You are feeding “View Name : ……” as a value in the Element.SetParameterByName
you can’t as Revit says cannot contain the following characters in this case thus :
You also want to make sure that you Apply the view names with the same FilterByBooleanMask because your current graph will not be naming things correct I don’t believe.
