Hi Experts,
I want to change the view name of 3D to the same as sheet number.I can’t choose 2 categories (Views and Sheets) at a time, If i choose only views as categories, while mentioning parameter of Sheets Number in string or code block it takes as text only not showing parameter value of Sheets Number. Please help me out, Thanks in advance. See pic-1, I want the changes like this. Pic-2 is my script.
I’d just select the view, from which the sheet number and view number parameter should be accessible. That can be pulled and pushed into the view name.
Hi @jacob.small
Actually I’m having 800 assemblies, need to change all 3D view names at once.
By select view I meant ‘all elements of category’ for views. No need to fetch the sheets.
Hi @jacob.small It works well, Thanks you so much.
