I am having an issue with my list.chop not working and I think it has something to do with the number I am inputting, it has 0’s after a decimal (image below) is there a way to get the 0’s to be removed?
Thanks,
Thanks,
pass it through an integer.
The node should work for both integer and double numbers. Are you sure the problem’s not in your “list” input?
Konrad-
Can you expound on what you mean by “Pass thru an Integer”? See image below - it seems like even nodes that are supposed to produce an integer (Math.Round) will result in a Double rather than an integer , even when an integer is passed into them.
Works well in both 0.9.1 and 1.0.
In 0.8.2 the output is inaccurate.
I’m in 9.0
KONRAD K SOBON thank you sir the integer was what I needed. Here are my results with the three of the “Math” nodes.
Tomek,
Dzieki za przyklad. Ja bym tylko dodal ze twoja funkcja to odpowiednik math.floor().
Niektorzy moga byc zaskoczeni jak zobacza ze int(1.8) to 1.
