List.contains not working
hello,
I got two issues one of them which is marked in red, all X vector has 0 value but when I’m collecting values it is showing some super precised value. That i don’t understand why its working like this.
Another issue is which is in blue, I’m trying to generate boolean mask for values containing 0 but its not working.
Where am i doing wrong? please help.
Thanks.
Because you’re asking if the string contains the number 0, try writing “0” instead :wink:
I tried this not working. :confused:
Neither ths working
In the first screenshot please show the preview under the “string from object” node…
In the second you’re comparing a “integer” with a “double” (try to use the “Object.Type” node to make sure you’re working in the right data type) :slight_smile:
i was trying to filter out all -1,0,1
now this is what i’m getting.
i got the reason behind is all values are have .000000 thats why its behaving like this.
So what is the correct direction for filter out 0 and 1?
Hi @ROY,
As @Jonathan.Olesen said, you are simply not comparing the same type of data :slight_smile: Please see below.
You could if you want integers either floor or ceiling the numbers…
not working.
thanks @Jonathan.Olesen. Now i understand.
I’m stuck on a similar issue. Trying to filter out items with a vector of -1 or 1.
I’ve tried this with strings & numbers and I can only ever get one of the list.contains to produce a ‘true’.
I have used both == and list.contains nodes.
Any ideas?
Good morning, at the output of your math.round node try this code in a code block
x>0||x<0?true:false;
edit: There is a solution 4 posts above
Cordially
christian.stan
