Reload families in revit using dynamo/Pyhton
Good evening, everyone! I’m new to Dynamo/Python and I’ve developed a Dynamo-Python script to load/reload multiple families in Revit by searching through a specific folder. However, I’d like to make a modification to this script so that it only reloads the families that already exist in the project, rather than loading all the families from a specific folder. I’ve tried using Revit’s ‘purge’ tool, but the drawback is that it deletes the types of families in the project. I want to keep the types of families that are already in Revit!
Here are the Python code snippets for the nodes.
WindowsForm Create :
clr.AddReference('System.Windows.Forms')
clr.AddReference('System.Drawing')
clr.AddReference('RevitAPI')
from System.Drawing import Size, Color, SolidBrush, Rectangle, Point
from System.Windows.Forms import *
from System.IO import Directory, SearchOption
from Autodesk.Revit.DB import IFamilyLoadOptions, Document
class FamilyOption(IFamilyLoadOptions):
    def OnFamilyFound(self, familyInUse, overwriteParameterValues):
        overwriteParameterValues = True
        return True
    def OnSharedFamilyFound(self, sharedFamily, familyInUse, source, overwriteParameterValues):
        return True
class TESForm(Form):
    def __init__(self):
        self.Text = "Families Loader/ReLoader"
        self.Width = 500
        self.Height = 310
        self.MaximizeBox = False
        self.MinimizeBox = False
        self.ControlBox = False
        self.FormBorderStyle = FormBorderStyle.FixedSingle
        self.ShowIcon = False
        self.StartPosition = FormStartPosition.CenterScreen
        self.TopMost = True
        self.values = []
        self.label = Label()
        self.label.Text = "--- NO PATH FOUND ---"
        self.label.Location = Point(20, 13)
        self.label.Height = 30
        self.label.Width = 290
        self.label.ForeColor = Color.Red
        self.button = Button()
        self.button.Text = "Nothing to reload"
        self.button.Width = 330
        self.button.Location = Point(20, 230)
        self.button.Click += self.setclose
        self.button.Enabled = False
        self.button0 = Button()
        self.button0.Text = "Browse..."
        self.button0.Width = 100
        self.button0.Location = Point(360, 10)
        self.button0.Click += self.OnClickedFile
        self.button1 = Button()
        self.button1.Text = "Exit"
        self.button1.Width = 100
        self.button1.Location = Point(360, 230)
        self.button1.Click += self.setexit
        self.list = ListBox()
        self.list.Size = Size(440, 150)
        self.list.Location = Point(20, 50)
        self.list.SelectionMode = SelectionMode.MultiExtended
        self.check = CheckBox()
        self.check.Location = Point(20, 205)
        self.check.Text = 'Select all'
        self.check.Width = 70
        self.check.Enabled = False
        self.check.CheckedChanged += self.checkedChanged
        self.Controls.Add(self.label)
        self.Controls.Add(self.button)
        self.Controls.Add(self.button0)
        self.Controls.Add(self.button1)
        self.Controls.Add(self.list)
        self.Controls.Add(self.check)
    def setclose(self, sender, event):
        for idx in self.list.SelectedIndices:
            self.values.append(self.list.Items[idx])
        self.Close()
    def setexit(self, sender, event):
        self.values = 'Exit'
        self.Close()
    def checkedChanged(self, sender, args):
        if sender.Checked:
            for i in range(self.list.Items.Count):
                self.list.SetSelected(i, True)
            self.list.ClearSelected()
            self.list.SetSelected(0, True)
    def OnClickedFile(self, sender, events):
        dialog = FolderBrowserDialog()
        if dialog.ShowDialog(self) == DialogResult.OK:
            self.label.Text = dialog.SelectedPath
            if Directory.Exists(dialog.SelectedPath):
                files = Directory.GetFiles(dialog.SelectedPath, '*.rfa', SearchOption.AllDirectories)
                for file in files:
                    self.list.Items.Add(file)
            self.button.Enabled = True
            self.check.Enabled = True
            self.label.ForeColor = Color.Blue
            self.button.Text = "Load/ReLoad Families from path"
            self.list.Items.Clear()
form = TESForm()
form.ShowDialog()
result = form.values
OUT = result
FamReloader :
elements = IN[0]
class FamilyOption(IFamilyLoadOptions) :
 def OnFamilyFound(self, familyInUse, overwriteParameterValues) :
  return True
 def OnSharedFamilyFound(self, sharedFamily, familyInUse, source, overwriteParameterValues) :
  return True
if IN[0] != 'Exit':
 try:
  for element in elements :
   doc.LoadFamily(element, FamilyOption())
   OUT = 'Families was loaded/reloaded'
 except:
  pass
 OUT = 'Exit'
I would like you to help me with this Dynamo/Python script to only reload the families that are already existing in a Revit project.
Thank you and have a good evening
Make sure you format any code as preformatted text (</>) so it maintains its structure.
I would suggest getting all families in the project and comparing that list of names to the file names in the target folder. Then you can choose to load or skip based on matches.
Good morning ! thank you for your answer, that means that I cannot directly make a modification to the python codes of these nodes directly, I have to change the sokution to be able to do this?
I don’t follow. You could automate all of this with python.
