Reloading Families through API crashes Revit
Hi Guys,
I try to reload/ load Families into revit through the Revit API. Therefor i created following Python script:
import sys
import System
import uuid #unique userID
clr.AddReference('RevitAPI')
import traceback
app = uiapp.Application
#Preparing import from Dynamo to Revit
List_ZG = IN[0] #list of paths of target families
List_Bauteile = IN[1] #list of paths of families
#Define classes & functions
#IFamilyLoadOptions Class
class FamilyLoadOptionsHandler(DB.IFamilyLoadOptions):
    __namespace__ = str(uuid.uuid4()) #defines Namespaces uniquely everytime the script runs, maybe temporary fix
    def OnFamilyFound (self, familyInUse, overwriteParameterValues):
        self.overwriteParameterValues = True
        return True
    def OnSharedFamilyFound (self, sharedFamily, familyInUse, source, overwriteParameterValues):
        source = DB.FamilySource.Family
        return True
#actual script
count = 0
outlist = []
for ZG in List_ZG:
    for Bauteil in List_Bauteile[count]:
        try:
            #ZG_Open = app.OpenDocumentFile(ZG) #backgroundopen trarget family
            Bauteil_Open = app.OpenDocumentFile(Bauteil) #backgroundopen family
            Load = Bauteil_Open.LoadFamily(doc,FamilyLoadOptionsHandler()) #load family into target family
            Bauteil_Open.Close(False) #close family, don´t save
            #ZG_Open.Close(True) #close target family and save
            outlist.append("true")
        except:
            new = traceback.format_exc()
            outlist.append(new)
    count += 1
OUT = outlist
The problem I encouterd is that when I try to reload a Family that already exists in the Project or another Family, Revit simply crahses and closes completely without the typical error window.
Doesn´t matter if the Family changed (currently only changing the geometry without a parameter) or not and if I the target document is a Family or Project File.
Since I´m still quite new to python and Revit API I´m not sure if I would need the Transactionmanager here, still tried it didn´t change anything (atleast the way i used it).
Here are my Test-files:
Familie2.rfa (688 KB)
Familie3.rfa (688 KB)
Test_LoadFamilies.rvt (3.5 MB)
2023-07-21_Test_LoadFamilies.dyn (15.9 KB)
Currently using Revit 2024 24.0.4.427 and built in Dynamo.
The goal would be to bulk reload around 200 families into different nested Families and projects (may take some processing time but still better then doing it manually).
Thanks in advance.
