Relinquish All mine in multiple revit models
After running a dynamo code that apply some actions on multiple models … i found that i need to relinquish all these models worksets …
So is there a solution by dynamo to perform this action for all un-opened models??
I found a node that synchronize and relinquish for current document but not for multiple models , this node is from clockwork
Any advice???
The API allows it :
SynchronizeWithCentralOptions Properties
http://www.revitapidocs.com/2018.1/72939a65-61bd-2055-dc75-5437eda64129.htm
RelinquishOptions Properties
http://www.revitapidocs.com/2018.1/14efeb6d-4feb-33f7-5b8a-3db14c54767a.htm
Clockwork has a great node for that for the current document.
So If I can borrow it and and modify it slightly, here is the result :
Thanks. Alo to i will give u feedback
I see that your graph is an example of one file. Can you explain how you get this to work on multiple files. I have tried it and it fails every time. Thanks
Use longest lacing and it will work.
I have changed the lacing to the longest, but i still cant get the rest of the files to go through successfully. I get the first on the list to return a “True” ,but the rest return a “False”. Any further advice would be much appreciated…
Update. It works now!!! I just closed the files gave it a day and retried it and it works as planed.****
Open_Project_Sync.Save.Close.dyn (22.0 KB)
I am trying to recreate the changes to the synchronize node, but have not been able to. Can you guys share or show me how to make the changes to have a document input and output?
