Hi, I am Civil3D user. Is there a way to split corridor baseline into multiple regions with an empty baseline with respective assemblies at a specified station interval using dynamo?
I have tried to use CorridorExtension.AddRegion node from Civil3d toolkit but it only gets random region order error.
I attached Civil3d dwg file and dyn file.(version Civil3D 2022)
Thank you in advance!
Corridor_region_random_order_error.dyn (73.3 KB)
Drawing1.dwg (947.7 KB)
Solved! Just Freeze and Run each section step by step。(If Run simultaneously,it will get random region error。)
Niice.
Not sure what error you get but maybe you can’t run all CorridorExtension.AddRegion parallell with each other.
Have you tried a Passthrough node? You create it using code block or if you have the Clockwork package installed it has the same node as well but as a Custom node. And then let the AddRegion nodes wait for each other to be run
Yes, I’ve already tried Passthrough node.In this Case,we don’t need to use Pass Through .
I built Custom subassembly by using Subassembly Composer,and added each corridor region with respective Assemblies.
It goes well without using pass through node.(If we also want to edit each subassembly parameter ,
we should automate with dynamo player cause it rebuits corridor very well every time. )
CREATE_CORRIDOR_REGION_WITH_EACH_ASSEMBLY.dyn (90.1 KB)
