Adding Civil 3D corridor Regions
I am working in a infrastructure project and I have to add multiple regions along the single baseline with same assembly, can anyone guide me how can I proceed with dynamo,
I have region start station and region end station in excel sheet.
Also when I will update/add stations in excel sheet my corridor should be updated as per data.
Hi @nazirforever,
There are a few other posts similar to this. Take a look and see if they get you pointed in the right direction.
Hi @mzjensen
As always you are the very first person to attend the question.
Actually in my corridor I don’t have any existing region to split so suggested method is not working,
even if I will create corridor to full length of baseline and I will split the region by using CorridorExtensions.SplitRegion Node there after I don’t see any node to remove unwanted regions. from corridor.
Can you please suggest some way to solve this issue.
Try adding regions using the CorridorExtensions.AddRegion node from the Civil 3D Toolkit and inputting the stations in reverse order, as mentioned in the first link.
@mzjensen ,
Thanks Jensen,
I am able to add new regions but not able getting any node to remove corridor regions.
do we have any node if not can you guide me how can I do this?
