Refresh Dynamo Player
Hello!
I have a problem with Dynamo Player. When i first run the script everything is okey. But when i edit in Dynamo player, and then run again, everything doubles up. Currently i have to run the script, then delete in Revit and then run again. I was thinking something like the refresh node from SpringsUI, but Dynamo crashes everytime I use it. Wondering if anyone knows a way to fix the problem?
Dynamo player doesn’t make use of element binding as the graph isn’t saved on completion of the run. As such each time you run the graph you will get new results, often on top of the previous one.
More info can be found in this post, or the AU course which is linked there.
