Hi. I am exploring the potential of Refinery to optimize beam section selections from steel frames. I am using Dynamo and Refinery together with Robot Structural Analysis for this purpose.
The script seems to run fine and the structural analysis too. My issue comes when reading the results in Refinery. The Output results don’t match the values that those Output nodes give in Dynamo. The Dynamo values do match the ones from Robot Structural Analysis. This happens even in really simple cases as the one in the picture attached. (Dynamo gives results in mm and Robot in meters).
Any idea what might be causing this?
Thanks,
Akira
