Trying to reference this thread, but it seems to be obsolete. Is there a way to control Referencing Sheet after the fact w/ Dynamo? If so, what Add-in packages are required?
… or should I just use C#.NET?
So, when you say “control” the referencing sheet, do you mean change the view it is referenced from" Like making a Section reference a different plan than the one it was cut from?
FYI, if it can be done in C#, it can be done in Python / Dynamo as well, just depends if what your trying to do CAN be done in the API.
