Reference Plane orientation
Hi guys!! :slight_smile:
I created a Refeence plane by using the ReferencePlane.ByLine node.
Do you know if there is a way to change its orientation, for example by changing its normal vector or something like this?
Thank you so much
Cheers
Valentina
you could try swapping start- and endpoint.
the line.direction node may help here
Thank you so much @Marcel_Rijsmus :slight_smile:
I’ll let you know if I work this problem out :smiley:
Unfortunately my problem persists.
Do you know if there’s a way to transform a Dynamo plane in a Revit reference plane?
I think it could be the shortest way to achieve my goal.
Thank you so much for your commitment :blush:
Hey,
Maybe this helps?
FlipRefPlane.dyn (14.7 KB)
Reference planes have a flip method…
http://www.revitapidocs.com/2018/3d4b050d-6f7a-1d67-c3c5-0fce92d5b25d.htm
Hope that’s useful,
Mark
# boilerplate from john pierson
# @60secondrevit, http://sixtysecondrevit.com
# Import RevitAPI
clr.AddReference('RevitAPI')
#unwrap Revit element to use with Dynamo API
rPlane = UnwrapElement(IN[0])
#start transaction
rPlane.Flip()
# 'End' the transaction
#Assign your output to the OUT variable
OUT = rPlane
(maybe @john_pierson would be interested in adding this to Rhythm)
Thank you so much @Mark.Ackerley :blush::hugs:
I’ll let you know :slight_smile:
to create a reference plane from a dynamo plane, create a new dynamo plane thats perpendicular and get the intersection of the two (it is a line) and create the reference plane from that line
Ok, I tried to run the script you kindly provided me, but the output isn’t the reference plane (as it shouls be) but 0 (and so the next node doesn’t work).
Do you know what I’m doing wrong?
Hey,
Could you post a dyn & maybe an rvt? (or a screen grab?) :slight_smile:
Cheers,
Mark
Sure :slight_smile:
Here it is the dyn file but unfortunately the rvt file is too big to be sent.
5. SOLETTA REV04_ref plane.dyn (153.5 KB)
So I try to post you a picture to explain my problem.
Here it is my viaduct model, and as you can see there is a slab (that I put in that position by using the Floor.SlabShapeByPoints node).
The very problem is that the analytical floor is stuck on its initial position:
and if I try to project it
The situation is this one (because iI don’t know how to change the direction of the normal vector of the plane after using the ReferencePlane.Line node)
I’m not sure I explained clearly my problem :sweat_smile:
Hey,
So unfortunately my Italian isn’t as good as your English :slight_smile:
But there are 2 problems,
First… you have have finished your python with OUT = 0, so that’s why you got 0…
Second… you are feeding a list, my Python was written for a single plane, try this instead (you can just copy and paste I think)
# Import RevitAPI
# Unwrap Revit elements for use with Dynamo API
rPlanelst = UnwrapElement(IN[0])
flprPlanelst = []
#Start the Transaction
for rPlane in rPlanelst:
    rPlane.Flip()
    flprPlanelst.append(rPlane)
OUT = flprPlanelst
Hope that helps,
Mark
Mark you are an angel :relaxed:
The funniest part in all this story is that I’ve never used Python before, so I’m quite ashamed by my own scripting errors :sweat_smile:
The other “funny” thing of this story is that I have that Revit(2019.0.1.1)-Dynamo(2.0.2) combo that presents the keyboard bug (e.g. ctrl+c and ctrl+v doesn’t work) so I’m forced to transcript the code by hand :woman_facepalming:
Hey,
Don’t worry, I’m no expert, but I would recommend a Python course, it will enable you to fill the gaps in the node libraries… Here’s a dyn :slight_smile:
Cheers,
Mark
FlipRefPlaneList.dyn (28.5 KB)
Edit: Apologies if you can’t even copy and paste between that :frowning: But writing out code is a good way of learning how it goes together :smiley: let me know if I’ve done anything wrong!
Anyway the first scritp you sent me works :partying_face: :partying_face: (I put in IN[0] an element instead of a list) and I eliminated the OUT[0] line (lol :rofl: )
Now my last goal is to use your script in a smart way in my project:)
About my transcripting work you’re definitely right :smile:
And thank you so much for the node and above all for your kindness and commitment :blush:
With respect to Reference Plane orientations, l created multiple cross sections aligned to a curve, as per the image, however, l required to have reference planes for each section, yet l am having to create the orientated RPs manually.
Any thoughts on whether Dynamo can created an orientated RP aligned to multiple sections? I have tried, but no joy sadly.
