Reference Plane in Revit
Hi guys :slight_smile:
Does anyone know why the hell if I create a Reference Plane in Dynamo by using the ReferencePlane.ByLine node, it still doesn’t exist in Revit? (even if the Dynamo node worked fine)
Thanks to everybody
Cheers
Valentina
Revit only lets you select named reference planes. It looks like your reference plane does actually exist in the model, you just haven’t named it yet.
Great! Thank you so much!!
Talking about the ReferencePlane.ByLine node, do you know if there is a way to change its orientation, for example by changing its normal vector?
With that node, no, it seems like it’s specifically set to cut through the z-axis.
The Rhythm package has a node for creating reference planes normal to the active view though.
