Move reference plane
Hello everyone,
I would like to ask if there is any way how to move revit reference planes?
There is way how to get dynamo plane from Revit plane, shift it and then create the new one. But I need to shift all original Revit planes becase of all links and elements based on them.
Any sugestions?
Apparently there are not yet nodes using the method ElementTransformUtils.MoveElement, all the translations node are moving the geometry, not the Revit element.
http://www.revitapidocs.com/2018.1/aaddd413-01b0-2878-3f79-a281abb6d364.htm
Said that, the python node is quite easy:
clr.AddReference('RevitAPI')
clr.AddReference('System')
elements = UnwrapElement(IN[0])
vect = UnwrapElement(IN[1]).ToXyz()
for e in elements:
	move = ElementTransformUtils.MoveElement(doc, e.Id, vect)
OUT = elements
MoveElement.dyn (7.6 KB)
Nice python script, but chances are the OOTB Element.MoveByVector node does the same.
:wink:
@Alban_de_Chasteigner, I would like to blame the Dynamo search engine and the 8 working hours, but this is really embarrassing :sweat_smile:
However a good lesson for the future, thanks!
Thanks a lot for your help!
Can’t believe that I miss thiss node …
