Hello everyone,
Is there any way to rotate a Reference plane inside Dynamo? I ahve tested the inbuild nodes. It seems to be inpossible with those nodes.
I have seen a post in Forum and there sombody suggest to create a dynamo plane with points and transform that dynamo plane to a Revit Refrence plane. But how would you do If you have a reference plane from Revit or from a Revit family that you need to work with?
Any package that has this necessary ability?
I think you talk about me ???
then i just will say rightover ![]()
You are using the wrong node
A reference plane is not a Family Instance
I think the node you are using is coming from a package since Dynamo has no inbuild Node with name âElement SetRotationâ. Could you please tell us wich package the node comes from? ![]()
