Reducing Panel Waste (Divide Surface into parts)
Hello everyone,
Can we divide the surface into 450x2400 panels to reduce panel waste as much as possible? like the image below:
Thanks, everyone.
Probably yes, but this forum is more for helping you where you get stuck rather than “can you show me how to do it”.
What have you tried so far? Do you have Revit geometry or just Dynamo? Do you need revit output?
If you need some background, the problem of finding the most efficient use of a cut sheet or linear material, look at the Cutting stock problem on Wikipedia
