Hi guys, I just started with dynamo and I have a question. I am about to finish my design in revit and I wanted to make the rendering and views as nice as possible. For this I’d like the walls to be divided in panels/rectangles. The size of each should be the same. But if the wall is finisched it should just cut off. And then I’d want to try and assign each panel a colour or material. Is it possible to use materials from revit in dynamo or would I need to assign them each in revit by hand? Thank in advance for the help. I attached 2 pics of the direction I’d like it to go.
