I use python code to get points, and I want to create rectangle.
But It show:
Warning: One or more of the input types are not matching. Couldn’t find a version of ByCornerPoints that takes arguments of type (__array)
How can I feed points?@mellouze
Thanks~
I guess you are not feeding points to Rectangle.ByCornerPoints. You might want yo check the type of data.
They are not points. you need to use a point.by coordinates after your python node
Create points as I showed you in the example above. You can use the same syntax in a Python Node.
If UX1,UY1, etc. are of type double, i guess you just have to replace :
U1 = XYZ(UX1, UY, UZ1)
by
U1 = Point.ByCoordinates(UX1,UY1,UZ1)
and so on.
I tried. @mellouze But It show:
File “”, line 65, in
AttributeError: ‘type’ object has no attribute ‘ByCoordinates’
To be honest, i don’t know. Have you imported the corresponding Dynamo functions ? What version of Dynamo are you using ?
Maybe I import too much things.
Thanks~ @mellouze
As far as i understand from the comment of @Thomas_Mahon (topic below), that could give problems.
https://forum.dynamobim.com/t/creating-line-by-two-points-in-python/14507/2
For the rest, interesting topic,learned some new things
Kind regards,
Mark
