I am not sure why I am getting an error with the Point.ByCoordinates in a code block?
I was just expecting it to generate the point not use Point as an input. Get the same error for both code blocks.
New to code blocks so any help would really be appreciated
Please try with Autodesk.Point.
Thanks for your help. Just for my own knowledge do you know why it is requiring Autodesk in front of it?
Looking at the Dynamo primer it should work without it?
Did another Google search with Autodesk.Point and found this link about the Rhynamo pacakge causing the issue.
Autodesk.Point.ByCoordinates?
Thanks again for your help.
Sorry I should have told you that. More info here:
and here:
