Hi All,
I’m trying to create a wall reinforcement using a custom rebar shape. I’m using Dynamo 4 rebar and BIM4Struc packages, but I can’t find a node qich select the rebar shape to use.
Does anyone came with some solution?
Thanks in advance.
Hi All,
Thanks in advance.
What do you mean by “qich Select”?
Custom node works as expected. I don’t see any errors.
Hi @Kulkul,
I meant “which select”.
I found those nodes that you are indicating, but my guess was pointing to a node like “Rebar.ByCurve” that turns the curves into a rebar element, so you could select the rebar shape to use.
My main issue was to create a rebar that has seismic hooks in both side, so when I use the “standard” style, it doesn’t allow this type of hooks. Now I’m working with polylines, created from a couple of curves and using the “stirrup” style with seismic hooks. I have to work a little in the custom shape created… but almost there. When I’ll have it I’ll post it.
Meanwhile, if you know about a node like described, I’ll be very glad.
Thanks in advance!.
Cheers
