Why yes I make rebar from polycurve can’t but if you use curve you can, while I need polycurve because there is iron whose vector connects, if you use curve it becomes 2 rebar, which should be 1 rebar
If you feed a flat list of 3 curves I think you’ll get a single rebar, right?
I’ve tried flatten curve he fixed it to 3 rebar not 1 rebar
If before I take my break you post your dyn and a sample rvt with just one element to host a rebar in it and I’ll have a look at it while I eat lunch.
sorry, i try flatten succes, It turns out that there is an error in my curve
