Re-import to revit
Hi Guys
I used this sets of code to get some of parameters of my element and bring them into excel, but from here i need to change those value in the given Excel and return it to revit, I’m not sure how to continue this process from export to excel group i created? Has anyone can help me to do the rest of process?
Thank you
A very large proportion of the posts on this forum are on this exact topic- so I recommend that you search & read through the posts.
The key point is that you will need some kind of unique identifier for each element- so that you can match up the reimported data with respective model elements. You could use the internal object ID or the ‘mark’ for each element.
Hi @Mehrdad.Ghanizadeh2R ,
This workflow looks like a great candidate for our private alpha testing program focused on Agentic AI and the Autodesk Assistant in Dynamo.
If you’re interested, feel free to share your email with me, and I can add you to the test group. With the provided guidelines, you’ll be able to use AI to complete this workflow — either by asking the Assistant directly or by using the Agentic Node to connect to Excel and Revit MCP servers for automated data updates.
You can check out this post for more information: Introducing Agentic workflows in Dynamo
