All these parameter are instance.
The values appear into other elements (see image).
The parameter “BT Code” ( in excel and Revit is unique ID parameter) with it I am trying to connect the information and add “Comment” and “Mark” values.
Dynamo should find the same “BT Code” value in revit and write the other values. Maybe someone has a solution or advise?
Could you maybe explain one more time what you are actually trying to do?
Are you trying to get Excel to Revit or are you trying to get Revit to Excel?
And what information is given to the other.
I am trying to import Excel values into Revit.
In Excel and in Revit I have the same parameter- “BT Code”, which is my unique Id.
BT Code is instance parameter in revit, the values are the same in excel and in revit. I want to keep this BT code as my identification number.
“Comments” and “Mark” values are just in excel sheet, I want them to be linked/ mapped into my Revit elements. But… To find the right elements in which values need to be written, I use “BT Code”.
What I cannot solve? With dynamo I tried to find the matching “BT Code” values in revit and in excel. If I find the same values, then dynamo will write my “Comments” and “Mark” in correct elements.
I was using this video to make the dynamo nodes. Principle is the same.
Maybe this will help you to understand me better.
can you help me to make a node in dynamo, which will find just those elements with matching values from excel sheet?
Okay i see, so you have an Excel file, which has all the information which needs to be added in three Colums:
BT Code / Marks / Comments and you want to import this data into your Revit through Dynamo.
