Push Edits from Excel back into Revit
All,
I apologize if this topic has already been covered. I am somewhat new to Dynamo and may not have been searching the optimal terminology to find any previous post on this topic.
The problem: I am looking for a way to push data that has been updated in an excel spreadsheet back into a Revit model using the element ID as a primary key.
Question: Is there a way to create a visual code that basically says "If components element ID in Revit matches a value in the element ID field (column), then use values in that row of data to update other fields in Revit (e.g. Room Name, Number, etc.)
Also, Would I have to build a separate script for each category (rooms, doors, MEP equipment, etc.) or is it possible to build a code that searches all element IDs in a project.
Thank you for your help.
This has been covered in significant detail… Look for select by element id.
Note that Element IDs aren’t necessarily static.
Check out the workflow displayed here for a start.
I would suggest that you spend some time ‘trawling’ similar posts that have mentioned “excel link” :slightly_smiling_face:
