Can anybody tell me if this package is still working right with this Dynamo version? Not sure what the issue is here. Many thanks.
What is the name of the package?
It is call QR Coder, last version is from 2016 as far as I remember.
It works with the current version, and older versions, so not sure why it wouldn’t work for versions inbetween
What is the output of your x+y node ?
It looks like it’s done in Python. Double-click on the QRCode node to open it, copy-paste out the contents and reconnect. This way you’ll be able to see where the problem occurs.
Finally I get it sorted out following your advice. Thank you so much to everybody.
