Hi.
I am trying to do “node to code” from dynamo, but it crashes. I tried for different scripts, but same result. Anything can be done about this?
I am using
Revit Version
18.3.1.2
20180423_1000(x64)
2018.3.1
Dynamo
Dynamo core 2.0.1.5055
Dynamo revit 2.0.1.5065
First update all packages to 2.x compliant versions if you haven’t already.
If you’re still crashing, Send a link to the screencast of the crash, your log files (available in the same appdata/roaming folder as the default package path), and a sample dyn which can replicate the crash.
I’ve noticed that some nodes don’t like to node to code in 2.x when there namespaces which use the same function name.
This may have to do with this :
