Creating a python node to replace our excel node as it bombed out due to gremlins(recent restrictions or changes on the network??? Reinstall didn’t work) So I am recoding excel.read and excel.write in a python node.
The read was a breeze. The write back has issues; Need to open an (existing) file and add a sheet, then rename the sheet- but cannot rename the sheet. Last line bombs out with error:
File “”, line 43, in
AttributeError: ‘DispCallable’ object has no attribute ‘Name’
Not sure how/if an UNWRAP could be done on an excel node to expose the classes directly.
###Import Excel - intended to replace malfunctioning excel node
### Ron.Allen@AECOM.com
clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=15.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c')
##AddReferenceGUID("{00020813-0000-0000-C000-000000000046}") ''Excel C:\Program Files\Microsoft Office\Office15\EXCEL.EXE
##Need to Verify interop for version 2015 is 15 and node attachemnt for it.
from Microsoft.Office.Interop import * ##Excel
################################Initialize FP and Sheet ID
##Same functionality as the excel node
strFileName = IN[0] ##Filename
sheetName = IN[1] ##Sheet
RowOffset=0 #IN[2] ##RowOffset
ColOffset=0 #IN[3] ##COL OFfset
Data=IN[4] ##Data
Overwrite=IN[5] ##Check for auto-overwtite
XLVisible = False #IN[6] ##XL Visible for operation or not?
RowOffset=0
if IN[2]>0:
RowOffset=IN[2] ##RowOffset
ColOffset=0
if IN[3]>0:
ColOffset=IN[3] ##COL OFfset
if IN[6]<>False:
XLVisible = True #IN[6] ##XL Visible for operation or not?
xlCellTypeLastCell = 11 #####define special sells value constant
xls = Excel.ApplicationClass() ####Connect with application
xls.Visible = XLVisible ##VISIBLE YES/NO
xls.DisplayAlerts = False ### ALerts
wb = xls.Workbooks.Open(strFileName, False) ####Open the file
wb.application.visible = XLVisible ####Show Excel
try:
ws = wb.Worksheets(sheetName) ####Get the sheet in the WB base
except:
ws = wb.sheets.add () ####If it doesn't exist- add it. ** "()" Required to instantiate method for object!
ws.Name = sheetName ####<<<<<<<BOMBS OUT HERE "AttributeError: 'DispCallable' object has no attribute 'Name'"
