I tried to extract the parameters of a window (height and width for area calculation).
For a window I do it with the code block, everything works:
I try with all kinds of project windows with Python:
I get the error in the line 31
I can’t understand why
Some help will be appreciated
Thank you
Try adding these lines as part of the imports (if you haven’t already)
They will add the dynamo design script classes
Thanks for the reply
I checked and those Dynamo design script classes are there
What does the warning say?
I don’t understand the warning… the kink
Parameter.Parameter By Name
works
You have imported both the Autodesk.Revit.DB.Parameter and Revit.Elements.Parameter classes so there may be some clashing or overwriting.
Comment out the following lines and see if that helps
clr.AddReference("RevitAPI")
hi, here is removing the number of variables and following Mr. Mike’s remarks
Don’t forget to put between < / >
your code
import sys
FIN=IN[0]
Stock=[]
for t in range(len(FIN)):
t3=FIN[t]
la=Revit.Elements.Parameter.ParameterByName(t3,"Largeur").Value
ha=Revit.Elements.Parameter.ParameterByName(t3,"Hauteur").Value
S=la*ha
Stock.append([la,ha,str(round(S,2))+" m²"])
OUT = Stock
Sincerely
christian.stan
jmark
October 17, 2024, 3:23am
9
my solution:
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
app = uiapp.Application
elements = UnwrapElement(IN[0])
area_lst = []
for element in elements:
width = element.get_Parameter(BuiltInParameter.FAMILY_WIDTH_PARAM).AsDouble()
height = element.get_Parameter(BuiltInParameter.GENERIC_HEIGHT).AsDouble()
area = width * height
new_val = UnitUtils.ConvertFromInternalUnits(area, UnitTypeId.SquareMeters)
area_lst.append(new_val)
OUT = area_lst
Thanks for the reply… works fine
Thanks for the reply…very interesting
hi, glad to hear it, all we have to do is close the topic as resolved
(choice of Design Script classes or Revit API classes that of Mr. jmark)
Sincerely
christian.stan
