hi, I want to select an object with the items entered in propertieset. For example, if you have a property value of A, is it possible to execute a command to select all solid objects with a value of A by executing the dynamo? I want to select only solid objects with a value of A and copy them to another drawing.
Welcome to the forum. ![]()
I am not sure I quite understand what you’re asking but I think you want to look at the properties first and then filter them based on some criteria?
If that’s what you’re trying to do then you can get a list of your elements and use the Element.GetParameterValue node to find the parameter values.
Then use a Filter by Bool mask to filter.
I want to select an object with the items entered in propertieset. For example, if you have a property value of A, is it possible to execute a command to select all objects with a value of A by running Dynamo?
Yes.
I’d get all your objects and look for that parameter.
Then I’d filter the outputs that match value A using a bool mask.
Thanks to you, I solved it!
