Hi! I’m using Dynamo with Alias and I’m not able to use ProjectInputOnto, as it gives an argument error. I can see it needs Geometry input while it is getting Nurbs.Curve/Surface as input. Earlier, it used to work just fine. I’m confused what to do next. Please help.
Vector.Z node is the issue. Perhaps you want the Vector.ZAxis?
Thanks a lot Jacob! It worked. I will keep this in mind.
