Hello
Can someone help me with this issue:
This happend a few times with different commands, and I don’t know how to fix this. I think problem is in the node, but don’t know how to edit that…I’m new in Dynamo and still learning basic operations
Check the out put from “Element.Geometry” node because it is probably outputting a nurbcurve already.
You can check the types with a “Object.Type” node which will explain what the objects are.
