I need to export the XYZ coordinates of a set of buildings to excel. I have each building location defined as a shared site. I’m using Orchid package Location.GetProjectPosition node but the numbers it is returning are not the same as the numbers I see in revit.
Example:
It is working OK for smaller projects but as the coordinates get bigger the numbers are more and more off.
The node is a black box, I have no idea what it does, I did not found source code. I’m looking for any other reliable way to list the XYZ for a set of buildings with shared sites.
Dynamo graph added for good measure.
LinkLocationToExcel.dyn (69.6 KB)
