hi, I have no idea if I am writing this in the correct place, but I would greatly appreciate your help.
I have a project where I have a north arrow on a sheet which I manage to link to the Angle fro, true north parameter from the Project Base point, if I choose the project base point as a select model element. But as I am working up our office template I need this code to know that i want the Angle to True North parameter without people having to open dynamo and editing it.
When i choose as the extract below the north arrow doesn’t change but when I choose the base point it works.
Try getting the project location. I believe there is info about true north in there.
Out of curiosity, why not use the actual north arrow on the plans, or at least make angle to true north a type parameter to minimize the times you’re gonna have to run this?
Hi, Please see attached images.
As far as I understand by doing select model element you extract the parameter value.
By doing anything else you basically creating a list with the desired value which does not mean anything to next node. Solution is apparently creating a new list with very first item of the previous list which will essentially report only the extracted value.!
First one is with ‘select model element’ see highlighted value.
