I want to export all parameters of Project base point into excel. For some reason, I am unable to export Angle To True North Parameter. can you help me to find the mistake in the code? I am using Dynamo 1.2.1 and Revit 2015
Thank you
Thank you
Hi @vamsi736,
You’ve typed the parameter as “Angle To True North” but if you use Revit LookUp, you’ll notice the “To” is without a capital letter. Try typing “Angle to True North” instead
thank you
