try
clr.AddReference('AcMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
#clr.AddReference('ProtoGeometry')
import Autodesk.DesignScript.Geometry
clr.AddReference('DSCoreNodes')
from DSCore import *
from System.Collections.Generic import Dictionary
cdoc = CivilApplication.ActiveDocument
def get_sample_line_info(sampleLines):
global adoc
global cdoc
output = []
if not sampleLines:
return
if not isinstance(sampleLines, list):
sampleLines = [sampleLines]
with adoc.LockDocument():
with adoc.Database as db:
for sampleLine in sampleLines:
sampleLineId = sampleLine.InternalObjectId
obj = t.GetObject(sampleLineId, OpenMode.ForRead)
objpv = obj.PVIs
for saPVI in objpv:
VerticalC= saPVI.VerticalCurve
if VerticalC:
output.append( str(saPVI.Station) + " "+ str(saPVI.Elevation) +" "+ str(VerticalC.Length))
output.append( str(saPVI.Station) +" "+ str(saPVI.Elevation) +" "+ " " )
outputFlatten =List.Flatten(output, -1)
t.Commit()
return output
OUT = get_sample_line_info(IN[0])
