I got the following python script from another post here (https://forum.dynamobim.com/t/dividing-parts-with-dynamo/5388.
Basically it converts a select wall to parts then sub-divides the generated parts into sub-parts.
Our design process is we convert all walls to Parts, so I require the python script to work on the selected part only.
As I am relatively new to python, I have been trying to modify it with out success.
clr.AddReference('RevitAPI')
clr.AddReference('System')
wall = UnwrapElement(IN[0])
divisionLines = [l.ToRevitType(True) for l in IN[1]]
sketchPlane = UnwrapElement(IN[2])
#Create a list for the wall and the divisionLines
wallList = List[ElementId]()
wallList.Add(wall.Id)
intersectionElementsIds = List[ElementId]()
curveArray = List[Curve](divisionLines)
#All actions that makes changes to the Revit database needs to be inside a Transaction
if PartUtils.AreElementsValidForCreateParts(doc, wallList):
createParts = PartUtils.CreateParts(doc, wallList)
doc.Regenerate()
parts = PartUtils.GetAssociatedParts(doc, wall.Id, 0, 0)
ipart = []
for i in parts:
if i = 2:
partDivide = PartUtils.DivideParts(doc, ipart[i], intersectionElementsIds, curveArray, sketchPlane.Id)
OUT = partDivide
Any help would be greatly appreciated.
Regards,
Eddie
