First divide wall into parts, then select all parts
I found this great post: https://forum.dynamobim.com/t/dividing-parts-with-dynamo/5388?u=voergaard, dividing a wall into parts - it works like a charm! :+1:
Now, what I would like to do, is to select the parts I just created and change "Mark" parameter.
This little operation however is starting to give me a headace :persevere::
  1. Dynamo returns a warning: a cycle dependency exists between two variables
  2. The script won’t “collect” all the elements until I run the script a second time, which obviously generates ALOT of other warnings. :slight_smile:
Any input will be greatly appreciated!
I’m running Dynamo Core - 2.0.1.5055
and Dynamo Revit - 2.0.1.5065
Post several screenshots or your files will be helpful
Sorry, I thought the .dyn file was attached.
I Hope that it is working now.
2018.08.29 - Wall, Divide Parts.dyn (71.9 KB)
your file works fine to me, it doesn’t prompt the errors you mentioned :sweat:. Could you also post your .rvt file as well ?
@jshial, you are right, I just tried to restart Revit and Dynamo - now the error is gone! :+1:
But when one problem is solved, a new arises. :face_with_raised_eyebrow:
I would like the “all elements by type” node, to select all creaded parts, not just one - how do I achive this if not by “all elements by type”?
I “always” test in an empty metric Revit project, but I’ll gladly attach the file: Divide wall.rvt (436 KB)
All Element Of Category can be very handy, feed it with Category.ByName(“OST_Parts”)
how do you want to set mark on parts ? I guess you need to reorganize the order of parts :thinking: , the order from All Elements of Category might be “chaotic”.
@jshial, you are absolutely right; the order IS chaotic - at best! :wink:
But I got that part figured out, fore the time being I’m using one script to divide the wall into parts, and one to change parameters for the parts.
Capture
I would very much like these two scripts merged into one, but I can’t figure out how to get dynamo to select the elements (parts) created during the running of the scripts.
As far as I can figure out, dynamo only selects the part present in Revit before running the script.
Let’s give it another go :smiley: :
Capture
This particular method is very handy :point_down:
http://www.revitapidocs.com/2018.1/73e42274-0b32-4109-db26-7c980504264d.htm
For combining scripts: after dividing walls into parts, you can retrieve parts for each wall by this method. (“include Parts With Associated Parts” or “not include Parts With Associated Parts” )
Thanks for the input it’s really really great.
But no matter what method I’m applying, I’m only getting the associated Part OUT, but not the parts I just created.
I don’t get it… :tired_face:
Is it even possible to divide the wall into parts and the select them in the same script??
it’s possible I think, you can just make it happend in the same Python Node, walls get divided first then just use that method to collect the parts from the walls. I need to look through the entire process recently to give a solid answer.:thinking:
Did you find a way?
