Create Parts of selection or result objects
Hey guys,
After creating walls by room boundaries using Modelicals “Wall finishes by room” node i convert these walls to parts and now want to further use these created elements.
sadly i’m not the best at using python and need help doing this. Output should be a list of the created parts for further use.
cheers and thanks.
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
#feed IN[0] with elements
elts = []
Ids = []
prt = []
for i in IN[0]:
	elts.append(UnwrapElement(i))
for e in elts:
	Ids.append(e.Id)
IDS = List[ElementId](Ids)
# Start Transaction tt
if PartUtils.AreElementsValidForCreateParts(doc, IDS):
	parts = PartUtils.CreateParts(doc, IDS)
#my nonsense trying to get These just created parts. or is there another way?
pid = PartUtils.GetAssociatedParts(doc, parts.GUID, false, false );
# End Transaction - by original script.
TransactionManager.Instance.ForceCloseTransaction()
#This was originally IDS but just gave me a string list of the parents IDs.
OUT = pid
#wallfinish.dyn (11.1 KB)
Hi @wunnenstein
Your getting empty values for wall finishes by room node. Make sure you have the wall types in your model. Watch this video https://youtu.be/RKE3Ph98Vns
Hey Kulkul. The main part of the script works correctly. I had to translate Modelicals node for using the German words (see the other thread I replied to recently). Maybe that’s why it didn’t work for you.
I just need help with the last part, having the parts elements the script has created as an output list to set parameter values to them afterwards.
Thanks.
