Get Element ID of Selected Element with Python Script
Howdy all,
I’m relatively new to Dynamo and especially Python. I am trying to get a grasp on how to create a python script block that will take the currently selected element in the model and get the element ID, so I can put it through other functions (e.g., get/set parameter of element(s)). I have done some searches, and found some solutions that I have tried to replicate. However, I run into an error with the GetElementIds method, which tells me that it needs an input. Everything that I have found online, showed that there was no input necessary. Does anyone know where I might be going wrong?
import System
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitAPIUI’)
clr.AddReference(‘RevitNodes’)
import sys
pyt_path = r’C:\Program Files (x86)\IronPython 2.7\Lib’
sys.path.append(pyt_path)
app = uiapp.Application
adoc = doc.ActiveView
sel = Selection.Selection.GetElementIds()
Any help/guidance/advice would be greatly appreciated!
Thanks!
Hi @wyatth_tgce,
Here’s an example:
Python:
#Import the Revit API
clr.AddReference('RevitAPI')
#Import DocumentManager and TransactionManager
#Reference the active Document and application
bool = IN[0]
if bool:
	sel = uidoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element)
	td = TaskDialog(str(sel.ElementId))
	OUT = td.Show(), sel.ElementId
	OUT = 'Set bool to true'
Like this?
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import Element
# Get the selected elements from the "Select Model Elements" node
selected_element = UnwrapElement(IN[0])
# Retrieve the element IDs as integers
element_id = [int(element.Id.IntegerValue) for element in selected_element if isinstance(element, Element)]
OUT = element_id
